Tire Question
new member/new DODGE
SNOW,
Ive been looking for some tires for my 99 quad 4x4. Currently running Michelin 265-75
on factory rims. Found a set of Goodyears,
same size with a more aggressive tread. The only differance is the Goodyears are load
rated "D" instead of the Michelins "E" rating. Reading the load rating on the side of the tire I note about a 400lb differance in the two. Is this enough to matter?? I dont carry much payload and towing is around
4K.
Serveral years ago I was the manager of a tire shop. I think you will be OK. The secret is you said you don't do much hauling and 4,000 on a trailer is no problem. If you hauled heavy or big 5er I would personally want that extra weight capacity. I have put 4,000 lbs. of feed in the bed of my truck several times.
2001 quadcab slt 2500 HO 6spd. LWB,2wd,dk garnett red, trailer tow package,camper special, anti spin 3. 54 axle, speed liner,oversized stainless steel chicken slide,66 gallon in bed aux. tank,K&N air filter,Reese 20k hitch, Terry 2000 EX 30ft. double slide 5er, 2000 20ft gooseneck for haulin jeep, firewood and huntin stuff. 5X12 tagalong for haulin the 4 wheeler. Okie Newton
i run load range D on my 2500 with no problems. routinely haul 425 gal of water (3400 lbs) and have hauled 4200 lbs of gravel and didn't have a problem. although i wouldn't recommend it for long distances or high speeds. run properly and cautiously when heavily loaded you should be fine with the D range tires.
Jeremy Kern
1999 2500HD 4x4 QC,SB, ISB, 5spd, 3. 54LSD, 33x12. 50 cooper STT's Denver off-road bumper with Ramsey RE12k, PIAA series 520 lights, Rancho RS9000's, heavy ft. springs, JVD Torque Enhancer, DiPricol boost and pyro gauges, and a bunch of other little things! www.geocities.com/phrn30 for pics!
