You really just need to type in "tires" in the "titles only" section of the TDR search engine and you will be able to read to your hearts content about all the options and opinions for different tires for our trucks. If you have a particular tire in mind that you want to research, type that name in as well and it is sure to come up. Just be sure to select the "title only" option first.
That being said, pretty much most people here feel that various Michelins, Toyos and Nittos are some of the best "E" rated tires for our trucks. I have run both the Michelin LTX AT2 265/70/17E and now the Toyo Open Country AT 285/75/17E. Both are excellent tires and will probaly last around the same mileage (25k miles). The Michelin was a little quiter and handled even better then the Toyo, but the Toyo is available in the larger diameter in an E rating, which gives me lower highway RPMs as well a load capacitiy of 3870# per tire. I have also just learned that the Toyos wear more evenly at 55psi on my truck. At 65 psi (which is waht I ran the Michelins at) the Toyos are slightly overinflated and wear the center down faster then the edges.
Hope that helps a little, but like I said you can learn ALOT more by using the search function.
