tire size,3500
Rust on the frame!
boost gauge install
To keep the tread level and wearing right you might not want to go over a 235-85. Your factory rims are only 6 inches wide. You can go bigger but you really need to watch your tire pressure for your tread wear pattern. A 255-85 will fit but... ... ... . Pete
Have 235's on mine. Especially if you tow I wouldn't go any bigger. If I have a load I need 75 psi. to be sure to not rub. Good luck.
Devon
