I have an '01 with the h. o. engine and 6 speed. IT has the 3. 59? gears. I will be towing about 10 K. Right now it has Cooper Dicoverer 285's on.
I need new tires. Should I go with 265's or can I go bigger? I was concerned about a problem with big tires and a high diff ratio. Most of the grades I will encounter will not be very bad.
Also, should I specify Load Range E?
