If you ever decide to upgrade the power a "Smarty" will cure the tire size problem. Shadrach
The '06'-'07's will stick when returned to stock. You have to physically return the tire size to stock which on mine was 31. 40". '05's on down will revert to stock automatically.I ahev heard that the Smarty Jr can reprogram the ECM for tire size also, but the change to the ECM does NOT stay with the truck if you return the ECM to stock programming.
