Q
Mactruck, I'm still trying to decide whether to go with a replacement set of 285 BFG All-Terrain KOs or up the ante a half size to the 295s. I currently have a brand new
(just pre) KO spare mounted on a fifth M/T Alcoa Challenger wheel (both have never hit the road). On one hand another set of 285s would work really well however, I have an idea that, in conjunction with a feature of the DTT Smart Controller (new version), I
might just be better served with the 295s. Another way to rationalize this theory would be that since the 295s are only . 600" larger in diameter than my new 285 spare... and given that a tire is more likely to go flat (due to a road hazard) when it is sufficiently worn, a worn 295 should be closer in diameter to a new 285 than a worn 285 is to a new 285.
Any opinions on this?
BTW, I'm
only interested in BFG radial All-Terrain tires... sorry, I cut my teeth on BFG radial Mud-Terrains.
<-- see?
Hey, better than a poke in the eye with a sharp stick, right Gene?
Also Mactruck, I believe the 295 All-Terrains are slightly taller than the 305/70R16s... but narrower.
