Tires - 255/85 or 285/75
South Bend (MU 2001 Con. FE) Installed
Well I Got my EZ Today..............
Within the next few weeks I will hopefully be putting some new tires on my truck. I am trying to decide between 255/85's or 285/75's
I know the stock chrome wheels (6. 5") are too narrow for the manufactures recommended rim width for a 285, but that doesn't concern me.
Here in MI where it snow a fair bit, I think the 255's will hold the road a little better because of the higher contact pressure, but will probably wear out sooner for the same reason.
I'm wondering what the fellas feel is a better choice?
Your comments are grealty appreciated,
Ryan
255s on the 6. 5" rim. I got ~50K out of a set of Dunlop Radial Rovers on a 2500 4wd gasser. I think my dad is at ~35K on a set of 255s on his 2500 4wd CTD.
Brian
I have 255 85's now, on my next set I think I'm gonna try 285 75's. I like the 255's, they're really good in the snow. I just think the wider tires would look better. Anything looks better when compared to the small 245's that are stock. I got a off brand tire. I have about 5k on them and they're at about 40% left, if that. I'll be getting BFG's next time, that's for sure. I like my 255's, but like I say will be changing just for the looks, it doesn't look bad by no means, but I like a wider tire look.
Corey
1998. 5 2500, 4x4, SB, Red Sport, Agate Interior, Quad Cab, O. H. Console, Auto, 4. 10 LSD, Trailer Tow and Camper Special Packages, Mopar Aluminum Nerf Bars, Spray In Bedliner, Pioneer/Jensen System, 255/85's, Bd Adjustable Preformance Box w/boost module, Boost Elbow, 4" Exhaust Split Into Two 3" w/5" cans, K+N Scotty Style, Exhaust Blanket, Bill K's Valve Body, Mopar Tow Hooks, Factory Fog Lights, Front Bumper Step, 55 watt Back-up Lights, Etc, Etc... .
Ryan, I have the 285 BFG's right now and I will be going to 255's next set. The 285's are wider and seem to follow the ruts worse than the 245 width. I want better drive quality so I will get 255's next time around. BTW, I have 24K on my BFG's and they are half or a little better left, great wear IMO.
EDIT: The 285's do really well in the snow, but forget it if you are on slushy roads. As soon as the salter goes by you better put it in 4wd.
99 2500 QC 4X4 AUTO SB 24V LARAMIE SLT 3. 5 LSD 285-75-16'S SPA Boost/EGT Rancho 9000's Everything but leather NRA Member Great Lakes TDR Member
[This message has been edited by LSMITH (edited 05-07-2001). ]
I run both 255s and 285s; hwy 255s in spring and summer, BFG Mud Terrains in fall and winter. Strongly advise 255s for all around hwy use; some are saying the wider tires are causing part of the problems with our steering wander. My rig definitely drives like a Cadillac with the 255s on it. fwiw
Wider tires look cool, and work better on surfaces requiring floatation, like sand.
Narrow tires are better in snow/rain/mud.
Provide less wander/pull and are kinder to ball joints, etc... .
Oh well, I like my 285's #ad
98. 5' Emerald Green 24v 2500 Auto/3. 54 4x4 SB QC 285. 75. 16's Bridgestone Dueler A/T's on 16" x 8" Alcoa's under Rancho 9000's. Everything but leather. PIAA 1200's, AMSOIL dual filter relocation system, Smittybuilt Stainless Steel Nerfs, Rhino Liner(Junk).
I run 255/85R16 Remmington Wide Brute RV's, an off-brand version of the Dunlops. They work great in the snow. If you want them to look better, get 16x8" rims, it made mine look a lot better.
Pete
'97 2500 CC 4X4 5spd Sport
'83 K5 Blazer 350 TBI (ex 6. 2), 39. 5 TSLs, 3" lift, Dana 60/GM 14 blt, Detroits
