tires for 05 3/4
aero tank for a shortbed... any experience?
Cooper Discover S/T 35x12.5x17- Will they fit a 2004 SRW?
Cooper ST have the following:
33x12. 5x17LT is load range D rated for 2600lbs
35x12. 5x17LT is load range D rated for 3000lbs
LT265x70x17 is load range E rated at 3195 lbs
Directly under the little specifications box is a link saying "View Full Specifications". Click that for a full listing of the tire specs...
Coincidentally I just went through replacing my factory BFG's and I ended up with a set of Cooper ST's in the LT265/70/R17 size. They seem to be a good tire thus far although I've only got a few hundred miles on them...
Cooper also has a 285/70-17. It is the same OD, (read height) as the 33-12. 50-17 but has a 3195# rating on a D tire. I have had a couple dealers try to talk me into the 33-12. 50 saying it's the same tire but it does not have the same rating. Just a FYI .
P. S. did not check the website, I just ran outside and checked :D
