Details here: TDR Privileges
This method worked for me and it checks against GPS and milemarkers on the highway. Example: I went from 265/75/16 to 305/70/16. (265mm/25. 4) x . 75 x 2 + 16 = 31. 65". Actual rolling diameter will be less but the calculated diameter works for this purpose.
The 305s dia. = (305/25. 4) x . 70 x 2 + 16 = 32. 81"
32. 81/31. 65 = 1. 037 or 3. 7% I use this multiplier each time I check my mileage. Hope this helps
I run 305s and have come up with 8% under for the odometer, but for some reason I don't know why but my speedo seems to be perfect, every time there is on of those radar signs along the road that say how fast you are going I carefully check it and I am always within 1 mph, over the past 4 or 5 yrs I have done this 50 times anyway always within 1mph
Way back when, my truck had 285's on it and my speedo was dead on. Now that I have 315's, the truck at 2000rpm, in 6th gear is indicating 72mph, Gps says I am doing 78mph. That is roughly 10% off.
