Please bear with me as this is long. My truck is scrubbing both the inside and outside edges off both the front tires. The dealer blames the tires and says the alignment and front end are good? The tire shop is blaming the front end and alignment? The tires are 305/70/16 D load range on stock rims and are inflated to 50 psi (max) up front and 40 psi in the back. The tire shop suggested the tires were underinflated until I pointed out they were at the max rated pressure up front. Also when I picked the truck up brand new it pulled left hard, so they aligned it before I took delivery. The truck also has a nasty wander and is hard to drive straight, especially with a trailer on it (4600 lbs, 400 lbs tongue weight). Truck has 10K miles on it now.
Any ideas or suggestion would be of great help as I am at a loss but my tires are wrecked after 10K and the stealer & tire dealer say I have to pay for them
Thanks in advance
Thanks in advance
