Tires
I want cloth power passenger seat, need info
Original Equipment tire valve stems on dually
I am looking for a more agressive all terrain tire I looked at the Good Year Wrangler ATS for my dually but the load range they had was a c range I need a d or better I just want to get rid of the Generals that came on the truck from the factory the really stink in the rain and snow and :confused: anyones suggestion would be appreciated Thanks Matt 2004. 5 QC dually Laramie 4X4
I'm also looking.
Trying to decide between BFG 285/70/17 AT or the cheaper ProComp 33/12. 5/17. They are both the same diameter, but the Pro's are about an inch wider.
The only real reason I am considering the ProComp is the 50,000 mile tread warranty and they are about $200 a set (4) cheaper.
MF
I'm curious do you have the optional OWL generals?. I forget which ones I have (my truck isn't near by) but my 05 came with them and these things work really well!!. Over the holidays I made a trip to Wa st from so Ca through Shasta and the siskyou (spelling) mts lots of rain ice and snow, and the dam things worked really well. There was a thread on here where a member had mentioned the availability of the Michelin 235/80-17E in May 05 that will be my next tire.
Mac :cool:
I'd suggest the MasterCraft Courser C/T to anyone.
1)direct replacement for your dually
2)load range E
3)plenty aggressive enough for most applications
4)should wear better than a true mudder
5)rides nice
6)$170/tire mounted and balanced
