Tires,
TDR page 84 Power Edge
Beware 25-0880 Pre Filter
Has anyone tried the Michelin LTX M/S LT265-75r16 and are they worth the $600. 00 plus price they want for them?
1994 2500 2WD 206,000 miles, TST kit, K&N,gauges
I have the 245 version. Load range E. I love them. I saved $ by getting blemished tires. Cost about $120 per tire. Same warranty. I can't see what is blemished.
Tim Barlow
My father has the Michelin 265/75/16's "MS" on his '96. He upgraded from the stock 245 Goodyear Wranglers. I have done the same but with the "AS". They are both OEM tires available when ordering an '01. The "MS" version is the upgrade of the two and has the raised outline lettering.
Both sets were bought as "take offs" from guys upgrading to larger tires. You should be able to buy a set of four as "take offs" or slightly used for a lot less than $600. 00.
I would think in the $200-$300 range plus mounting and balancing. Go talk to your local tire shop that does a lot of aftermarket tire & wheel upgrades for the local dealers in your area and watch the TDR online classifieds.
As far as performance, we both have seen an upgrade in handeling and performance over our stock 245 Wranglers.
Terry S. '98 Quad Cab SLT, 2WD, 12V, 3. 54, AT, Trailer tow PKG, Camper PKG, OEM cab lights, 4" exhaust turndown, 5th W. Hitch, roll-top cover, tint, high performance K&N air filter, 265 Michelins and turbo silencer ring in tool box!
BOMB'n in Tacoma, WA.
Member of the NW B. O. M. B. er's
18,900 miles - 4/16/00
I replaced my worn out tires with Michelin's and the ride is a lot quieter, seems to handle nicer but I lost about 2 MPG, from about 20-21 to 18+/-. Not sure why this happened. The previous tires were a very agressive M&S tread. I went to LTX A/T's 265/75/16 and cannot understand the lose in milage. Other than that I was very pleased with the tires.
94 2500, AT, 4x2, 80,000 miles
My mileage also went down when I went to the 235x85-16s, unitl I slowed down. #ad
If you go the same speedometer speed as before, your truck is going faster down the road. Boy does it take more fuel to push our 6klb, ultra aerodynamic beasties down the road. I dropped the speedo down to 66/67 to go the old 70 & the mileage came back up. Also, they are a bunch heavier than the old tires & it takes more fuel to accelerate them @ the same rate as before.
Money Sink - 96, 5 speed, SLT, 4X4, LWB, Ext Cab, ISSPRO pillar, TST 280/685 all the way forward, AFC housing all the way forward, Delvac 1 & Amsiol, Injectors, K&N, Monicas silencer ring removed, Exhaust brake, 4" CAT back & CATless, 4" chrome turn down straight out back, Mag-Hytec, 3:54, 235s.
This topic is of interest to all forum users, and applies to more than just TD powered Dodges, even.
To get wider exposure, I'm moving this over to the "products" forum, in hopes to get wider play and more visibility.
Thanks for participating!
Mark
ICQ 3807791 (BBSMan)Home Domain www.my2kcity.com (Under construction)
Email powerwagon@mymailbag.com
12 Valve Forum moderator and Procrastinator extraordinaire...
Tow-er '65 Power Wagon Crew Cab, Tow-ee '70 Boles Aero 28'
Those of you that are getting lower mileage with the larger tires, keep in mind that your speedo is off and if you have not re-calibrated the speedo it will seem as if you are getting much worse mileage.
In pacing my truck with a stock one as well as mileage markers, I have found that I need to add approximately 10% to my mileage calculation.
Example, if I go 450 miles on a tank, I need to add 45 miles (10%) to that figure before calculating my mpg, as I have actually travelled 495 miles but the speedo only measures 450.
Hope this helps!
19,300 miles - 5/7/00
CAW440- The Michelins are twice the tire that the Goodyears are. Try the above mentioned sources for "takeoffs", or go to Price Club/Costco. They seem to have the best deal on tires I've found.
2001 QC Dually SLT+ 354 LSD AUTO 4WD Driftwood SS Railcaps Stainless Werks step-rail nerfs Rhino spray-in liner Aux B/U lites Diamond Plate Alum Highways tow box SS Fender lips Jardine 4" Mag-Hytec diff & transmission Alcoa classics Reese 20K hitch 28ft Holiday Rambler 5er w/slide 84 Scrambler 4" lift 33/12. 50's 4. 56 gears soft locker/trac-lok Built 258 w/Mopar fuel injection conversion BUILDING 66-442 Olds, ground up--OH BABY! NRA 25 YEAR MEMBER
I have been using Michelin tires for the last 25 years with absolutely no problems. They are more expensive than some of the other brands, but in my opinion are worth every penny. On my 88 Olds (98) I had 110,000 K on set of Michelins before I replaced them with another set of Michelins. On the 92 Ram I replaced the original All Season Michelin tires at 9,000 K with set of Michelin XPS and now have approximately 64,000 K on them and they will probably last for another 15,000 - 24,000 K. For my use the Michelin have proved to be an excellent tire and considering the reliability and mileage that I get out of them they are not that expensive.
92LE,Cummins,tach,4x4,5spd,Borgeson steering shaft,
My 01 2550QC came with the Michelin LT265/75R16E and I love them. Very good tire.
01 Ram 2500 QC LWB Cummins
Dark Garnet/Driftwood
All options except heated leather seats
And I Love it!
Try SAM's club, I saw them in there for around 120. 00 including mounting.
Eric Pitts
2001 Properly Valved 2500 Qcab 4X4 auto 4. 10 LSD Prime-Loc
Weston Nerf Bars Smith built brush guard
Command Remote Starter
Neophyte B. O. M. B. er
Terre Haute Indiana
The Pitts Home Page
Member GLTDR
While we are on the Mich LTX tire subject, I'm looking to put 285-75-16 on a set of 16x8 Alcoa Classics for the spring/summer/fall months, and the stockers with snow tires on for the nasty salty winter months.
For the Alcoa's, I really like the Michelin LTX's, but haven't seen em in 285's. I've also looked at a set of Yokohama's Geolanders, but don't know their wear/noise charactoristics. They seem plenty agressive for a summer tire. Furthermore, I'm one of those guys who can't just go to a tire place and say "put a set of tires on it". I gotta see em. If they don't lateral rain grooves... I won't buy em. This throws the likes of a BFG A/T out the window. I've also been looking at a set of Goodyear ATS's, but have never had luck with GY's in terms of wear. SO... Like everyone else here, I'm looking for a rugged tire to last forever...
Any suggestions. . ??
98' 24v 2500 Auto/3. 54 4x4 SB QC. Everything but leather. AMSOIL oil filter relocation kit w/secondary by-pass unit,Smittybuilt Stainless Steel Nerfs, Rhino Liner, K&N. Somehow lost my silencer Ring.
Still wishin I could put my M3's mile deep paint job on the truck. Or maybe I should wish to swap its perfectly engineered automatic. Or maybe... . Ah heck, Just wish BMW would start makin a truck using the ISB!
I want to go to a taller tire on a 2500 2WD. I looked at the 265- 75 -16 Has anyone done much towing with this size? I am conserned about the side wall flex,causeing the rearend to sway under load . this tire has a Max presure around 60psi where the 245s I have now is 80psi. Thanks for any ideas.
Steve
95,2500,auto,410;2-WD
Gear Vender Overdrive
tst-250hp
