To do list for new (2003) truck
grid heater reprogramming
Massive amount of fuel in oil, how to find the culprit?
The lift pump is new so next time it dies, I'll swap it over to the in tank fuel pump. I'll just keep an eye on the fuel pressure.
Buy a spare and keep it in the glove box. $$ expensive $$ to change to an in-tank pump. Besides you got other options like a belt drive lift pump from GDP and other electric pumps. The only reason my 2003 didn't get it bolted on was it didn't clear the 6.7 crank damper I had on it. With my prior bad luck with GM lift pumps I had the GDP kit in my hands.
Good point, the block mounted lift pump isn't bad to change, the in tank one is a bit of work with an empty tank, with a full tank itd' be a nightmare
Well, the intank often lasts half a million Miles or more. So, no problem there.
The intanks are proven reliable, where the other ones are not. So simple it is.
Yes, watch that psi gauge.
My stock pump went 135K before checking out. I should have recognized that it was checking out because I always had 7-8 psi until it started to get cold and then show 4psi. It would recover a bit and then drop to 4 again. (yes I know, what good are gauges if you don't listen to them). This action went on for about 2 weeks of bouncing back and forth and then she left me on the side of a road headed to elk camp with a full fuel tank and trailer.
I got it towed home, siphoned the fuel out (used 8 of those clear 5 gallon water jugs because they are cheap) dropped the tank, completed the vent mod, cleaned the tank, threw in the Fleece Power Flow and she is happy again.
Was it a engine block mounted pump that went 135k or an intank pump?
It was that cute little pump located on the back of the stock filter housing that failed. The embarrassing part about it is that I thought the truck had been retro'd with an in-tank pump because when I turned the key I could hear some buzzing back by the fuel tank. As it turns out that was my airlift pump. I have only had the truck for about 6 yrs and when I inflate the airbags I never put the two sounds together as its the same thing. SMH! Ill chalk it up to an educational learning experience. lol
My compressor on the exhaust does the exact same thing to me but I thought the lift pump was the exhaust brake compressor. Turns out my exhaust brake compressor is deader than a doornail but my lift pump works great...
