I've got oil leaks at the oil pan gasket, front gear housing cover gasket, oil cooler gasket and at some other minor locations. I was going to replace the gaskets and check and repair other leaks as they become evident. This is a Freightliner FL70 with a 5. 9 12 valve Cummins aerial bucket truck with 190000 miles on it with a number of hours in idle time when the truck is in PTO lift mode. The truck is in good condition and everything works, and for a 93 it runs great. My question is at this time should I think about a rebuild or only replace parts as needed. With the leaks described is there another course of action ? My purpose is to keep it stock and run it for another 190000 miles. Dependability rather than speed.
