I am about to re-assemble my rear trailing arm/brake backing plate/wheel hub and bearing assembly as part of my 2008 Jeep Patriot overhaul.
Thanks!
- I am planning to put anti-seize between each mating surface. Good idea? Bad idea? Where else should I consider use of anti-seize? Should I use anti-seize on all of the suspension component bolts passing through a bushing?
- I was planning to reuse the bolts that hold the wheel hub to the trailing arm. They appear very sloid and the head of the bolts were the least rusted of all the bolts on the rear suspension area. I was going to wire brush the bolts well. Think this is OK?
- I am planning to put BLUE Permatex threadlocker on the bolts that hold the wheel hub to the trailing arm. I believe I want BLUE and not RED. Correct?
- Is there anything I can use on the threaded ends of the bolts on suspension components to keep them from rusting so bad? Should I use threadlocker on these bolts?
Thanks!
