I thought I would share some thoughts about slide outs. Some people like them some don't. Last summer we bought a newer TT. We went from an older 24' model to a newer 28' with a 13' x 40" slide out.
First the "faults": In my case the trailer is not only longer but heavier. Second the trailer now requires a wider camping spot. You have to watch out for trees and over hang of big branches. Since I don't have a ladder ( yet ) on the back of the trailer I now have to carry a step ladder to make sure there are no leaves, branches etc on the roof of the slide before I bring it in. I know a slide out awning would help in this matter but we have a skylight over the table and my wife doesn't want to cover it up. At one site this summer I had to back in far enough to "fit'' the slide between 2 trees only to discover the awning on the other side wouldn't go out because of trees. I seldom camp in open fields.
If it rains I have to make sure the majority of the water if off the slide roof before I bring it in for travelling other wise I can, and have, brought in water. There is more maintenance required. A lot of trailers have a floor plan designed in such a way that with the slide in the trailer is almost useless. Example My brother can't access his fridge with the slide in. This may seems irrelevant to some but when you are loading the TT and it is parked on the street in front of your house you can't extent the slide out into traffic. Or if you stop for a snack or a coffee while travelling it can be a pain.
Now for the good news. With a slide out, or 2 or 3, you now a lot more room inside your unit. You could possible make do with a shorter trailer or coach as it is now wider. A lot of trailer now have them available.
If you are on a budget and can't afford a high rated unit and you still want a slide buy a good quality used model. DO NOT buy a cheap brand with a slide. I have seen the walls crack from the corners of the slide opening upwards. The extra leverage the slide puts on the unit can cause flexing and twisting of things that you don't want to flex or twist.
Shad
Shad
