Todays active topics
Jump to box on bottom
Switch of towing and comp forums
Today's active topics should update continuously. You should only see "today's active topics" if you aren't logged in as well - once you are logged in that should change to "view new posts".
-Steve
Yep that's what I meant was "View new posts" isn't that supposed to change once a day? Another thing why is the clock under it so far off? Thanks for the answers Steve.
No, view new posts should update every time you log in to the site. You can also use the button on the left at the top that says "view last days posts" and that will bring up all the threads with activity in the last 24 hours. The time is set to GMT on the server because we have users from all over the world. If you click on usercp in the upper right hand corner and then click on user options down near the bottom you'll see where you can set what time zone you are in.
-Steve
