Well their up and running, it is a pretty intense install, but all in all not to bad. I ended up making a new bracket for the transmission dipstick tube, so I could move the tube towards the center of the motor (this way it cleared the down pipe). It comes out inbetween the top turbo and the valve cover. I had to make the bottom turbo mount to hold the weight of that turbo. I also used a different heater hose that fit a little better than just bending the hose (factory hose kind of kinked when trying to hook to II coolant line). Other than that everything else was pretty much bolt in.
I have only started to truck as of right now, I couldn't drive it yet because I needed some more transmission fluid, Because I finally put on my Mag-Hytec pan on that I have had for awhile now.
So once I run to town and get some transmission fluid we will be going for a test drive.
I hope that they work as good as they look under the hood! I took a few pictures of the install so I hope to ge them posted soon. Well I better get to town!!
Snoxracer
