I just use the wifes old bathroom scale...
No guys, she's not that big. Just some rather simple physics at work.
I used a 5 foot 4x4, a few 1 foot pieces of 2x8, wifes scale and some scrap pieces of pipe.
Do this:
1. ) attach two 6 to 8 inch pieces of pipe to two chunks of 2x8 such that the pipe can not roll on the 2x8.
2. ) place the bathroom scale about 2 feet to the left of your trailer tounge.
3. ) place a piece of 2x8 about 1 foot to the right of your tounge (no pipe). this is just to get the right side at about the same level as the top of the scale.
4. ) carefully mark the 4x4 in 1 foot increments (make sure you can align to the marks both at the top and bottom).
5. ) take the two pieces of 2x8 with the pipe on top and place one on the scale and one on the other 2x8 (with no pipe).
6. ) lay the 4x4 accross the two platforms created being careful to align the pipes with the measured marks on the 4x4. You should have the pipe on the scale exactly 2 feet from where you will place your tounge and the pipe on the two pieces of 2x8 exactly 1 foot to the right of where your tounge will sit. When I do it (allowing for extra 4x4 to stick out on both ends) I have the following reading from left to right. 1 foot = pipe on scale, 2 feet = nothing, 3 feet = mark for trailer tounge, 4 feet = pipe on 2x8's.
7. ) position the trailer so that the tounge jack is in the proper position (1 foot from the pipe on the 2x8's). In reality you'll probably just position everything under the trailer tounge in the first place.
7. 5) zero the scale.
8. ) jack the trailer up and note the weight read by the scale. multiply that number by the number of feet between the pipes. In this case the multiplier is 3, you could make it 4 if you have a heavier trailer. If you measure at 1 foot on a 4 foot chunk of wood you are reading 1/4 of the total, if you measure at 1 foot of a 5 foot piece you are reading 1/5 of the total weight.
Oh crud,
I just found a link that explains it with a picture..... go figure.
http://www.rverscorner.com/articles/tongueweight.html
