I have an 04 Ram with an in-bed fuel tank/tool box that the top of sits even with the bedrails of the truck. I want to put a tonneau cover on my bed to keep the leaves and debris out of my bed and I also occasionally pull my fifth wheel so I would like easy on-off capability. The few tonneau covers I have seen use side rails that intrude too far into the inside of the truck bed to be usable with my combination. I've only got two inches of clearance between tool box lid and inside of bed rails on either sides of toolbox and only inch and a half or so between front (towards cab) of tool box lid and inner side of bed rail where front mounting clamps would go for a tonneau. The width of the toolbox is 23" deep into the interior dimensions of truck bed so I should be okay as far as side clamps would go for the tonneau as long as they're not closer than 23 1/2" or so to the front of the truck bed.
Are any of you using a tonneau cover that sits on top of the bed and don't have framework that protrudes into the interior of the bed ? I need easy access to the front of my bed in order to fill my aux tank and occasionally open the tool box. I haven't been able to find any local dealers with inventory I can look at.
I just sent some emails out to a few manufacturers but probably won't hear anything back till next week. It looks like the Tonnopro brand has covers that will work with my setup.
Any feedback is appreciated, especially if you have a Tonnopro cover on your truck or have the same setup as I've got and can make a suggestion or recommendation. Thanks in advance !
