transmission troubles
Hi there. Im a little new to the cummins world so youll have to forgive my ignorance. The other day I was driving my 97 1-ton 4x4 5 speed down the Hiway when all of the sudden the 5 gear started making alot of noise. Needless to say my 5 gear is out. all of the other gears work fine. I am the second owner of the vehicle and it has 134,000 miles on it 17,000 of which I put on. I havent done any hauling with it. why do you suppose this has occured.
Second. I assume that the transmission is factory. Can I put a tougher transmission in. should I just change out the 5 gear. or could i convert it to a 6 speed transmission. What are your thoughts. By the way it is a cummins 12 valve.
