This past weekend I installed a BHAF on my truck. I couldnt even get the tires to break loose after that. One other problem. From a standing start it takes off slower than before, revs up to 3300 RPM, Defuels, then shifts into second and continues to pull hard. Why does it fall on its face so bad? It is like it cant shift fast enough into second. I put stock air box back on, now I can smoke tires and doesnt fall on its face. This was on the 100HP setting of the xzilliraider box. I always thought that more air the better? Is it the cp3 not keeping up? Can someone explain the air flow dynamics of this one? Is there a cure for this when using a BHAF? Thank You.
