shawn huizenga
I've got a question about smoke on my dad's '01 2500. There's a brief description of the mods in my signature. The question I have is about how much smoke I can reasonably expect from this thing. It seems that when its at any throttle position and load it could use a few pounds more boost for the fuel its receiving for the situation. For example you're gradually accelerating from 65-70 with a constant boost of about say 12 pounds, everything's running fine but it just seems to constantly smoke like it needs a little more air or a little less fuel for that load situation. I've tried running with the box off, and on setting 1X1 and I really can't tell any difference in the smoke nor defueling at lower boost readings that should be taking place with the box on 1X1. When we were adding mods to this pickup we thought we'd have a relatively smoke free towing vehicle with the box turned off(EDM Mach 2's only), but it seems to be always throwing some black smoke under all loads from empty to towing a 32' fifth-wheel camper. I'm just not sure what the deal is, maybe we need a smaller turbo, maybe the map sensor's bad I just thought I'd get you guys' opinion on this before I did too much more. I appreciate your replies and hope you can help me out.
Thanks
Shawn Huizenga
Thanks
Shawn Huizenga
