Took RAMifier box off, have P0193 code?
Fan Clutch gonzo for the 6th time, what is causing this?
occasional hard start/long crank time
Gents, (I Tried SEVERAL searches)
I took the RAMifier off my truck without disconnecting the neg battery cables. Plugged MAP and FP sensor cables back in. Truck immediately throws P0193 Rail Pressure sensor high code.
I put a SnapOn tool in the OBD port, it doesn't show a code to be cleared... the truck however still shows the code and the Check Engine Light is still on... I have checked and rechecked the connections. Still have CEL light.
any ideas what's going on?
Thanks,
Andy
recheck the plugs and make sure that none of the pins are slightly bent causing a weak connection, I have taken mine off many times and have never had a code pop up after it.
Well, I checked and re-checked, and re-checked again. We were at a local meeting when I took the box off ( I sold it to a guy with a TST. ). MAN, that IS a nice stack!! wow... but anyway... the code was gone this morning? Go figure. Thanks for the help though.
Andy
