Tool Question
tools....best bang for buck
Millermatic 135 or Lincoln SP-135 Plus?
I'm having a hard time finding a tool I need because I don't know what it's called. It's used with an air compressor and threaded into the spark plug hole to pressurize a engine cylinder to keep the valves from dropping down when changing springs or in my case the valve stem seals on my Toyota.
Also if you know who sells this tool that would help... ..... Thanks
A leak down tester would work.
Myself I just take a spark plug for the engine in question and knock out the center and braze in the air fitting I use in my shop air system. Then hook up an air regulator to controll how much air I want in the cylinder. :D
