Top Secret Bombing about to happen!
Jake brake use.
Idling blues
Ok guys,
I have a bone stock CTD with 9K (except my K&N) that I would like to BOMB a little. I'd like to spend around 500-600 to get started. Nothing to evasive. Something I might possible HIDE from the dealer if need be:D I want some more horsies. What do you all recommend? Ya might keep in mind the auto transmission:rolleyes: Maybe a black box or some other electro gadgets that make things go fast :D ;) Thanks Mark
I think the edge EZ sounds to my liking:D I will probably get the guages first though. Since I am not a wiring genius, I hope the guages aren't to big a bear cat:eek: to hook up. Maybe I can get some coaching from my TDR brothern, when I get all that ordered! Thanks for the posts guys!
Dash, by all means, gauges first. Try to include a fuel pressure gauge with your install, well worth it. They aren't hard to install, if you encounter a question, just ask away. After that I would add the Edge EZ.
Scott W.
I'll Lend a Hand
DASH,
When you get the gauges, drop me an email or message and I will let you know what days I have off and I can run down to help you with the install. Should only take a couple of hours or less for me to drive from Topeka. And the install is pretty painless, I have done mine and helped a couple other people in the past. I would agree with the others that the EZ is the easiest install and removal.
TR
well if you want it to be a secert , this is NOT the place to post about it ...
the walls have eyes ... oh well who cares ...
anyway , gauges and an EZ are a good place to :eek: START ??? :eek:
