When unlocked and under load, such as towing up a steep grade, use the least possible amount of throttle to hold speed. With a 10K# 5er in tow I was pulling the steep grade out of Taylor, BC and was caught behind a loaded dump truck doing 25 mph. My transmission was all stock and building heat very nicely. This caused me to throttle back some and I noticed that my speed had hardly changed. I had been turning about 2250 rpm and holding about 25 mph in 2nd. I had reduced rpm to 2100 and was still holding the same speed. The temp climbing was greatly reduced and readily noticed (probe in cooler line). In short, don't rev above the efficient fluid coupling in play. Feather/feel the throttle to speed situation and don't shear the transmission fluid anymore than absolutely necessary.
