Hi everyone.
For the second time now, a torque converter bolt has loosened, made contact with the engine/transmission adapter, and sheared off.
Page 21-1038 in the 05 factory service manual says to torque coverter bolts to 35 ft. lbs.
First time I installed the (suncoast) converter, I used blue loctite and tightened to 35 ft/lbs. I pulled the inspection plate on the bottom of the bell housing about a week later after a grinding noise developed, and a converter bolt head fell out. I pulled the transmission, took the converter to a machine shop and had them remove the broken bolt. The threads in the converter looked fine. I reinstalled converter, torqued all converter bolts to 42 ft/lbs upon reinstallation. Again used blue loctite.
Now a month or 2 later, another converter bolt loosened and sheared... Has anyone torqued these bolts higher than 40 without negative results? I am still reusing the remaining converter bolts from my original transmission. Should I try red loctite? Just wondering.
Asking for advice so I don't cause this to happen again. I love this transmission, but I'm sick of pulling it from under the truck...
Thanks
Ben
Thanks
Ben
