I installed a TC lockup switch following the directions from
TST web page. The directions state that the trans will not shift out of 4th gear once locked. I am experencing a down shift even when the lock up switch has been applied. If I apply the maximum throttle the trans will down shift then go back into lockup. The switch does have to be turned off in order to stop or the truck will stall.
My question is this. Is the trans supposed to still down shift between 3rd and 4th even when the lockup switch has been applied.
Thanks for your help.
Don Vizgaudis
Don Vizgaudis
