JBoone:
Welcome to the TDR Website!
You will have to try and attend one of
our N. C. TDR meetings down near Raleigh
sometime. We met today in Smithfield and
had about nine trucks show up.
To answer your question, I have a "Pro-
Torque" Torque Converter and BD Valve
Body on my truck and have had no problems
with either of them. I see you have a
95'Dodge. If you are "rebuilding" the
transmission, make sure you have them
replace EVERYTHING while you are in there!
(i. e. clutch packs, seals, etc. )
At 98,000 miles I replaced ONLY the T/C
and valve body and 10,000 miles later I
had to go BACK IN and have everything
done as the transmission began "revving
up" between the 2nd and 3rd gear shift.
Clutch packs and seals were worn!!!!
I should have done all that the first
time but didn't. My fault..... but it cost
me more money than it originally would
have. (BTW, the problem had nothing to
do with the new T/C or valve body. The
metal discs in the clutch packs were gone
and the seals were bad!)
Also, watch the stall speeds of the new
converters. If you are not planning on
modifying your engine, try to stay a
little closer to the "stock" stall speed.
My "Pro-Torque" T/C had a stall speed of
1600 RPM and before all my engine mods.
I had a "flat spot" or "lag" off the line.
I got my T/C and valve body from "Scheid
Diesel" in Effingham, Illinois. Their
phone number is: 1-800-669-1934.
Alot of the other members have reported
very good results with Bill Kondolay's
new T/C and valve bodies. His new
company is DTT (Diesel Transmission
Technology). I am sure some of them
will see your post and give you a
report on Bill's products.
Hope this has helped you some.
John_P
Red '96 4x4 2500 Auto 3. 54, TST #5, Major Pump Mods(By "Scheid Diesel") 370 Diamond B Injectors, Gov. Spring kit, AFC Spring kit, Banks Exhaust, Prime Loc, Cummins Chrome Kit,Psychotty Air Filter, Pro-Torque Converter, BD Valve Body, BD Pressure Loc, Isspro Gauges, Sendel 16" Alum Wheels w/ 33" BFGs
