I have the dreaded TC lock unlock problem. . Here is what i have done so far to cure but seems to get worse. . Reset APPS/Tested Batteries/Installed Happi Box/Cleaned Gray Connecters on Grounds/Cleaned ground on PCM... I have a Edge Comp and it does it worse with the Comp on... it runs good two days after i reset APPS but then it comes back... I have no codes and it runs strong... I dont know what else to do or check... Plz help
