Torque Converters
Is this a typo?
tailgate for sale?
Has anyone had any experience with Suncoast or Dunrite torque converters? I have a 1996 2500 4wd 5. 9 12v with a 354 rear end, with a phase II Dr. Performance (I know, I know, he's a jerk!), pulling a 9500 lb. 5th wheel. I have to upgrade TC but I'm not sure what's fact and what's smoke and mirrors. Any help would be appreciated.
I have a Dunrite converter, 1400 rpm stall according to the box and Trans Go shift kit. Installed Feb. 20, 2000 and no problems so far. Have put about 4000 miles on it, towing about 80% of the time. The stuff I tow only weighs 3k, not anything like these 10k plus 5th wheelers like many of the other guys. But I do live on an island that is actually the top of a mountain, so I am towing up many hills, some pretty steep. Bought this from TST, who told me a stock engine would not be able to pull this converter, it would bog, but if you had at least their #8 plate, 230hp/605lbs kit, no problem. I am running their #5, (270/670). Stock I would see the tach go to 2000 rpm before I felt the truck start to move. Now the truck moves just before the tach shows 1500. To me it has made a huge difference and trans does not have the slippage like it had before. A friend of mine who has an ISB with the VA & BB set at 15% and only the BD valve body, is going to put in a Dunrite after driving my truck and seeing the difference in TC lockup. I don't know anything about the SunCoast, except from the pictures it sure looks pretty. Kind of a shame such a nice looking part would be hidden from view.
1996 3500 Clubcab SLT, auto, 4. 10 limited-slip, TST #5, K&N, Dunrite converter, Trans-Go shift kit, Straight pipe, DiPricol EGT, boost & trans temp. gauges, 9 ft. aluminum flatbed and tool boxes with Venco dump. Custom front bumper, Hadley air horn.
Lil' Smoker, Our rigs is twins (almost). I put the trans-go and Suncoast in about two weeks ago. Wow what a difference. I have yet to tow with the new converter, but will tow 10,000# to Soldotna AK this weekend. Last weekend I hauled down 1000# of lumber in the bed and could'nt tell it was there! You sure can feel the difference with the lower stall and firmer shifts. I ONLY WISH I WOULD HAVE UPGRADED MY transmission FIRST! The stock setup is a JOKE.
'96 2500 extcab, SLT, 4x4, auto-3:54 LSD, Dr. Performance#2, Psychotty Air (no ring), American wheels, 255/85R16, Bushwacker flares, 4 inch Jardine T to T, Mag-Hytek tran & rear, Suncoast low stall and Trans-go kit, Rhino Liner, EGT-Boost-Tran temp on dash, Reese Titan V hitch... Triple axle Haulmark enclosed toy hauler
Contact Roy @ MAG-HYTEC in Ca. 877-786-6816
He has researched the Suncoast and now recommends it. Roy is a good guy and a straight shooter. He also drives a 95 Dodge
Cummins.
dunrite is the best convertor for a cummins,tony will custom build to your needs,fyi the suncoast was designed/and engineered by tony of dunrite,give him a call you will be glad you did ,can answer all your questions,and more.
