Dr. Kayak,
Do you have 4. 10 gears? Your rpm and speed is the same as mine when this happens. Does this happen at light throttle or going up a slight grade? I've had this shudder/hesitation, what ever you want to call it for about 15 month. I had it before the EZ went in. I and many other have this problem. If you could do a search, you'd find a dozen threads on this. It's not the TC slipping and it's not caused by the EZ. Althought the EZ does seem to acserbate it. One or two folks have solved it by replacing the following, VP44, IAT sensor, MAP sensor, APPS, etc. They are the few. Many have replaced some of the above listed parts and it didn't help. So far, I haven't heard of anyone finding a solution for the problem. Some folks have suggested that it's something in the ECM. I have noticed that when the weather warms up the problem goes away. Have you noticed this more in cooler temps? We have had some 90* temps and it disappeared. Today it was in the mid 50s and it was back.
I have talked to a Cummins tech, and he said that they can hook up their computer and take a road test and determine if it's the ECM (or some other engine related part or sensor) or the transmission. I haven't done this yet because they can also tell what mods you've had on the truck. I'm sure there is a test that a transmission tech can perform to determine if the TC is slipping too. Sorry, I couldn't be more helpful, but it may give you some peace of mind about your TC.
Tom
BTW I have a DTT VB. It's a good way to go even if it doesn't solve the shudder problem. Hopefully I get the TC in soon. It's sitting on the garage floor w/ all the other associated parts.
