torque for stud install
pdr hx40 or stock hx40 for 2004.5?
So let's hear about Stanadyne
I started my stud install this morning and now I can't find the instructions. Do you bottom them out and then back off a half turn? And is the final torque 125ft/lbs. These are 12mm studs from PDR.
RonA
Make sure they bottom out, I believe it is 75, 100, and then 125 ft lbs. Make sure to follow the correct sequence for tightening.
Also make sure that all washers and nuts are coated well with the supplied lube!
