torque spec
Check Gages light
Debate: Do 4.10s get lower milage than 3.54/3.73s?
Looks to be 22 ft-lbs from the manual:
"All high-pressure fuel lines are of the same length
and inside diameter. Correct high-pressure fuel line
usage and installation is critical to smooth engine
operation.
(1) Position fuel line support clamp to fuel line.
Install clamp nuts/bolts and tighten finger tight.
(2) Position proper fuel line to proper injector on
engine. Tighten fittings hand tight at both ends of
line.
(3) Tighten fuel lines at high pressure injector connector
to 30 N·m (22 lb. ft. ).
(4) Tighten fuel lines at fuel rail to 30 N·m (22 lb.
ft. ). "
etc.
