mwilson
Can any of you fine folks with the factory service manual take a minute and get me the torque specs for the following parts???
I had planned to get a CD from Geno's in the future and did not anticipate a front end rebuild this quickly. Could pay air freight but with all of you guys on here I figure someone has it right at their fingertips.
Tie Rod End Nut
Hub Bolts
Hub/Axle Nut
Upper Ball Joint Nut
Lower Ball Joint Nut
Brake Caliper Bracket Mount Bolt
Brake Caliper Slide Bolt
Thanks in advance for your help.
Mike
Tie Rod End Nut
Hub Bolts
Hub/Axle Nut
Mike
