Torque Specs for G56
first FF change.. report
trouble code ?'s
This probably won't paste right, so the first number is N/M, second is Ft/Lb. There were none listed in In/Lb. Taken from 2006 FSM.
MANUAL TRANSMISSION-G56
TORQUE SPECIFICATIONS
DESCRIPTION N·m Ft. Lbs. In. Lbs.
Fill Plug 57 42 -
Drain Plug 57 42 -
Front to Rear Housing
Bolts
58 43 -
Input Shaft Retainer Bolts 23 17 -
Shift Tower bolts 23 17 -
5-6 Shift Fork Bolts 58 43 -
Shift Rail Support bolts 58 43 -
Reverse Idler Gear Shaft
Bolt
58 43 -
P. T. O. Cover Bolts 58 43 -
Clutch Release Pivot Ball 22 16 -
