Doing it by the book involves measuring the running torque on the bearing without the seal installed, and then reinstating that torque after installation so it is a fairly complicated process.Does anyone know the torque specs for the nut on the rear differential pinion on an 03 Ram 2500HD with 6 speed? My seal is leaking and I need to replace it. Thanks.
There is a teeny tiny bit of play in the bearings. I didn't measure it, can't see it, but I can hear a little it when I move the shaft from side to side. I would like to tighten to take up that play.
