Torque Specs Help
6.7 Longgivity?!?!?!
Vacuum Leak?
i was looking on the web for specs on the oil pan drain plug and the wheel lugs on a 2010 dodge ram 3500, 6. 7 Cummins.
i take it there is no service manual out yet. i cant find anything on one.
new here. hello all!
thank you for any help given...
2010 Ram Owners Manual >>>>>
(in your glove box)
"Install the drain plug and sealing washer and tighten to
37 ft-lbs" .
"Correct nut tightness is 135 ft. lbs. (183 N·m) torque for 2500/3500 single rear wheel
(SRW) models and 145 ft. lbs. (197 N·m) for 3500 dual rear
wheel models.
