Torque Specs
Last one ton non-dually
Aerodynamics
I need to change my transmission fluid tomorrow... . Does anyone have the torque specs handy for a 2001 automatic transmission oil pan and filter?
Thanks,
Doug
Torque spec:
Doug: turn 'em 'till they strip, then back off half a turn :D :D
If I remember correctly the spec is about 80-100 INCH pounds. But I found that just going around the pan several times using a 1/4" drive ratchet gave better results.
My pan developed a leak with the 'torque it once and forget it' routine. I believe it was the pan gasket slowly relaxing and this resulted in a leak.
Check them in a day or two, I always find one or two not as tight as the others.
Did you run the 1/4 mile yet??
Greg Long
torque
I have a 2001 also.
From the FSM page 21-473
Bolt, fluid pan... ... ... . 17 N-m (13 ft. lbs. )
Tom
edit:
Also from same page
Screw, fluid filter... ..... 4 N-m (35 in. lbs. )
