AMink
My Wildcat TT has torsion axles. The tires on the left side wear fine, but the ones on the right side show cupping on the outside of the tire. The rear tire is especially bad, front not too bad. I am not, however, convinced that the axle is out of alignment as the tire is also showing signs of structural failure. At one point across the tread, the tread is almost flat side to side, the rest of the tire has a pronounced hump around the circumference. So, the question becomes, is the tire failure caused by bad alignment or is the wear caused by tire failure? Can torsion axles be aligned? How do they do it? I know all about the Chicom trailer tires but before I drop some serious change on new rims and tires, I need to know if these axles can be aligned if needed. Also, if they can't, can traditional axles be installed?
