I think we have all seen the claims about the PE Module. . and who wouldn't want one... ???
I know from some people that the piercing of the wires that go to the pump WILL LEAVE SIGNS THAT IT WAS INSTALLED. . !!
Granted... the PE solution is more eligant than "Scotch Locks" . . But a simple "Wet Conductivity Test" will show that the insulation was indeed pierced. .
Now. . I also know that the VA box is the choice of stealth bombers out there because it uses the same connectors as the factory setup!
Next issue. . The PE people offer a module specifically designed to work with a VA Box. .
How do we utilize this to out advantage?? Simple. .
Follow me on this one... .
(Stock Setup)Pump--\\---------Factory Harness
(VA Only) Pump--\\-----Va------\\-----Fct. Harn
(STD PE) Pump--\\-------^^-------Fact. Harn
(VA+PE) Pump--\\--^^----Va----\\----Fct. Harn
(ALT. VA+PE) Pump--\\----Va-----^^--\\---Fact. Harn
\\= Factory type connectors
^^ = Piercing type connectors WHERE THE PE TAPS IN!!!
As you can see since PE offers a "With VA Box" cofiguration... the only differance is where the wires get pierced.
If the VA's wires are the ones to be pierced. . then as soon as the VA comes off the truck. . there is NEVER any indication that either the VA or the PE were ever there!
ToTal StEaLtH... .
Work With me on this... It has POTENTIAL!!
Larry
'98. 5 24V 2500 C. C. SLT, 4X4, Auto, SWB, Forest Gr. /Driftwood
7 + 7/8 coats of wax... Yes Sir That's My Baby WOOHOO!!!
ToTal StEaLtH... .
Larry
