Tow Dolly???'s
Keystone Raptor Toy Hauler
2 car hauler
Going to be using a rented tow dolly later this summer to travel from Washington to the Chicago area (2100+ miles) towing a Honda Accord.
Would like to see some advise/thoughts from those who tow with a dolly (i. e. speeds/do's/don'ts/rental pitfalls/towing experiences, etc).
Towed trailers for years, but this will be a first... .
Thanks for the help... ;)
I've towed some with a dolly. Not much unusual about it. However, backing up can be an adventure so watch where you park.
I pulled one on a 1200 mile trip with a 97 cutless on it. Ruff bridges in a curve @70, on wet roads, glad I had a 1 ton flat bed, be carefull. Other than that Hammer down.
I know this'll sound dumb, but I towed a Dodge Stratus on a dolly for 500 mi after I picked up my first CTD:
Don't forget to unlock the steering wheel!
Learned from (painful) experience!
Juan
Make sure the one you rent has good tires. Check the tie downs every time you stop. Use the safety chains. If you have a CB it can come in handy if a trucker wants to tell you about a problem. Stopping is a thing to practice even with a light car it can be a chore to get stopped. I have used a tow dolly behind a motorhome for about 70. 000 mi. Only problem I ever had was caused by one of the tie down straps on a wheel got loose and fell next to the dolly wheel and cut the tire. It won't back up and remember that when you get fuel. Also get used to the passing distance. Don't want to make it sound difficult because it isn't.
The lights on it should be all you need to be legal, but they are 1/2 way up the car so assume that people may not be aware of you at all times, maybe the rental place will provide magnetic lights.
RJOL,
Tow dolly advice:
Get a trailer instead of a Dolly if that's an option. They're a lot easier to back up (and your car doesn't have to ride at an angle and scrape the underside of the rear bumper in dips).
Ditto earlier advice about using tie-downs and safety chains. Also, re-tighten the wheel tie-down straps after only a few miles - they settle in quickly and loosen up. {Standard advice for tie-downs it to check no less frequently than every two hours or 100 miles, whichever comes first, and at every stop. If they've been staying tight consistently, the 2 hours/100 miles may be a bit conservative. }
With a dolly, don't go anywhere where you will have to back up. It's worse than backing a double trailer, because the dolly acts like a very short trailer. The dolly backs like a trailer - the car goes the other way and jackknifes - and there tends to be limited clearance between the dolly fenders and your car's beautiful paint job.
Check dolly tires and bearings (temperature) at every stop. Lights, too.
Rental tips:
Check U-haul.com now and periodically before your trip. Generally speaking, the earlier you make the reservation, the less expensive it may be.
Print out the reservation information! On a few occasions, rental places have "misplaced" the (much less expensive than walk-up price) reservation - until I pulled out the printouts.
When checking for reservations on the web, try other (particularly small) towns near your pick-up and drop-off cities. It can sometimes make a big difference in price.
Happy towing!
Alan.
livetodrive's advice on the bearings and tires is a good point. All you have to do is touch the bearing cap to know. My wife says I look like a vehicle worshiper, kneel feel the front wheel, kneel check both duals, kneel check dolly wheel and bearing, go to other side and repeat. Only takes a few seconds.
Thanks for the info... This trip will be almost all freeway, so I think I'll stick to the dolly (half the cost of a car hauler). I know about the backing problems.
If you go with a rental, check the condition of the axle itself, particularly in the center where the pivot hole is located. I once had a dolly where the axle steel was fatigued right in the middle, and as I loaded the car the axle snapped like a twig.
Upon further inspection the axle was full of stress cracks. I thank God that it failed during loading and not while on the Interstate.
- Mike
