My trucks did not come with tow hooks so I was planning on buying a set. I looked on eBay and found several sets of new hooks only, one set without any bolts was buy it now for $65, I was going to buy it but I figured with the shipping and then having to find the grade 8 bolts I might as well buy them from the dealer for $115. I also called the on-line places but they were not any cheaper when you added in shipping because they are so heavy. So I got the tow hook kit from the dealer, when I picked it up I asked if the mounting hardware was with it, the counter guy said he thought so as it was a "kit". Yesterday I decided to install them, turns out there are 4 brackets that come with the hooks that tie them back into the frame, the install was kind of a pain because you have to unbolt the intercooler and lift it up slightly, the point of all this is if I had bought the hooks off of eBay they would not have come with the 4 brackets although they would bolt right on without them, I would not have known there were additional brackets, probably the 1st time I would have used them they would have tore the front brackets and the hooks right off the truck, so if you are going to buy the hooks be sure you get the brackets as well. The kit also came with all the bolts.
