2nd Gen Non-Engine/Transmission tow hooks
Engine/Transmission (1998.5 - 2002) Jacobs Exhaust Brake
DO not use the $10 tow hooks that bolt directly to the frame with two bolts. The Dodge OEM tow hooks are a far superior product. The front receiver for $100 from JC WHitney is also good, but I don't think it's quite as strong. I've had both on my truck. I'm now using the front reciever because I have a receiver mounted 8000# Warn winch.
I just went through this issue and ended up purchasing a Darwtite front mount receiver and step to mount in it for less than the cost of the tow hooks at the dealer. Now I can move my boat a lot easier.
The drawtite is rated for 9000lb pull and 500 lb vertical.
