2nd Gen Non-Engine/Transmission Tow Mirror Conversion
Engine/Transmission (1994 - 1998) turbine housing & pyro tapping
2nd Gen Non-Engine/Transmission 4 inch exhaust questions
I did the tow mirror conversion and I wanted to share some added info to Klenger's directions. I had purchased a couple of the power/heat 3rd gen mirrors on ebay that were damaged
The driver's side mirror had a hole behind the mirror on the flip out part that was only exposed when in tow position. I was able to remove the mirror glass and holder from the mirror motor, there is a clip on the backside of the glass that when released, lets the glass come out.
Then I unscrewed the motor out of the broken casing. I popped out the retainer clip and spring at the pivot point of the mirror box. On one of the manual mirrors that I had purchased, I was able to use a torx bit tapped to a 1/4 inch wrench and unscrew the entire mirror assembly with the mirror glass still in place. PITA, but doable. Then I also removed the clip and spring at the pivot point. You have to remove the spring so you can remove the manual mirror assembly. Now I put the mirror motor into the position in the formerly manual mirror box and screwed it into place.
Next, I carefully popped off the cover from the mirror arm and used a ball joint press with a 30 mm socket on the clip to compress the spring and clip back into place. Before I put the cover back onto the mirror arm, I ran the wiring to the base and also made sure that the covers matched. There are two different styles, one is manual, the other is the motorized either one will work, but I didn't like the indent under the mirror when in tow mode.
On the passenger side, the mirror had a damaged base. I followed Klenger's instructions, but I also removed the arm cover so I could again use myball joint press to reinstall the spring and clip on the 2nd gen base.
I had bought a total of five mirrors for the conversion, an excellent right side 3rd gen, two damaged 3rd gen mirrors, an excellent left 2nd gen manual mirror and then two brand new 2nd gen manual mirrors. Originally, my intention was to install the motors from both damaged 3rd gen mirrors into the two brand new 2nd gen manual mirrors. I soon found that this was not going to work because at some point, they change the manufacturing process. The brand new manual mirrors are now glued into the mirror housing as opposed to being screwed in. Fortunately for me, the single left 2nd gen manual mirror I got was old enough that it used screws internally.
One more thing, the wiring, on my 95, it was green to green, blue to blue, and red to grey. I will wire up the defrost part later to a basic switch.
If you have read down this far, hope this helps and sorry for the long post.
Craig
Do you know if all trucks are wired for power mirrors. I bought mine used and it has heated electric tow mirrors on it, but has no control for it in the cab. Appears to have been purchased new without power mirrors and somebody added these. Do I need to just by the power mirror control switch?
I am not sure. If you remove the door panel on the driver's side, there would be two connectors, one for the mirrors, the other for the switch. They are located to the upper forward part of the door. If not, then you buy a switch and wire the mirrors. I would want to have a wiring schematic when doing this.
My old mirror on the 95 had a flat three wire connector. The 3rd gen mirrors have a square connector for a possible 8 wires even though only 5 are in it. Yes, I cut off the connector including most of the wires from the connector to the old mirror. Then I hard wired the mirror control wires to the connector. I also ran separate wires for the defroster. I plan to hook them up with a simple rocker switch that is on the accessory power.
I also just did the conversion. My truck is an ST model, so it wasn't prewired for power mirrors. I used 4 wire trailer wire to run from the switch to the passenger mirror. Three conductors for the mirror movement and one for the heat. I grounded to the door.
Here we go again!!!!!
Who currently has the best price on the 03 up power/heated mirrors? Did the conversion to flipups on my 95, now will swap them to the 98. But, I got used to the heat this last winter on the shorties, so... ..... Now it`s time to finish the job & get the power to them flippers! So, who is dealing on them now ? Thanx, DK.
one of mine has come loose, around the pivot point, and has cracked... I tried some JB Weld, but it seems to still be wiggling. . If you take apart the manual mirrors, can you put the motor on the bracket that is inside behind the glass? I really hate to have to buy a new mirror assembly just for that one part... help chime in, por favor! Thanks!
-Chris-
Found them here for $269
Mirrors
The guy also sells on e-bay all the time with buy it now prices that are sometimes better. I am not affiliated with them in any way.
-Chris-
As I mentioned when I started this post, Yes you can take the power mirror motor and put it into the manual tow mirror, but only on the older manual tow mirrors. At some point, the manual mirrors started to be glued into the housing. It seems to me that if you could get the manual mirror out and clean the glue out of the post, you may be able to screw the mirror motor into the base. I did not want to chance it and possibly ruin a perfectly good set of mirrors to find out, so I used a different set of mirrors to do my conversion.
