I just bought a 2005 3500 Laramie with the Tow Package, which apparently only included the 7-pin connector. After reading the manual (as a last resort, mind you) I discovered that the 4-way connector under the dash is an option to the optional tow prep package.
My question, where do I get this 4-way connector and where then do I hook this gadget into? The manual states that this 4-way can be found to the left of the brake pedal under the dash. There is some kind of ribbon connector sticking out right below the dash, but it has more than 4 connectors. I presume this is the connector for the test equipment, etc.
I just bought the Prodigy controller with the OEM Dodge quick-connect wiring harness. I was hoping this would be an easy 1,2, 3 but I was wrong... .
Thanks.
NevadaBadBoy
Thanks.
NevadaBadBoy
