Towable boat with a Cummins?
Dodge delivers the mail
Guns, Bows, Shooting Sports, and Hunting Beretta PX4 Storm!
Doesn't look like you could tow that thing without a "Wide Load" banner on the back!
It's cool though.
I was just thinking that I've never seen a boat on a trailer that had a Cummins in it as far as I know. That's a heavy motor for a boat, and I was wondering if you'd need a wider beam to support it, or if it doesn't matter. I believe the max you can tow, width-wise, is 8'6", and I'm sure there are exceptions.
Oh I think you could repower a smaller ski boat such as a corrrect craft, etc with a Cummins. Or perhaps a shamrock maybe. You would want a straight inboard for sure as an outdrive wouldn't last too long.
The issue with a small boat will be getting a large enough diameter wheel to absorb the horsepower.
There are a lot of boats in the 22'-26' range with Cummins power.
Or Yanmars..... ours has a Yanmar... . 24'
Extreme End of Towing..... and the best White Water Boat made... ... these boats are Stick Steer - Pioneered by Bentz
Hells Canyon Adventures uses a 40’ Bentz Boat powered by three Cummins 315hp diesel engines and propelled by three Hamilton 273 jet pumps to transport up to 49 passengers in the wild and scenic section of the Snake River in Hells Canyon of Idaho, USA.
Bentz boats unique hull configuration, properly matched to engines and pumps, can haul over 10,000 pounds of cargo in water as shallow as 0. 2 meters (5 inches). Let Bentz design and build a boat for you that will increase your cargo capacity and your profit.
Great Video on Hells Canyon - Bass Boats Need not Apply... . :-laf
http://www.bentzboats.com/wsindown.mov
http://www.bentzboats.com/culebra.pdf
2 – 315 hp Cummins diesel
2– 273 Hamilton Pumps
http://www.bentzboats.com/gustodelrioII.pdf
3 – 315 hp Cummins diesel
3 – 273 Hamilton
Got to yachtworld.com and type in Cummins as a keyword, and maybe 18 to 27 feet as a size.
Many to choose from actually.
If you really want a Cummins powered boat. You are going to have to custom order a boat form any boat manufacture that is power by a Mercruiser and request if they would be will to install a Cummins Mercusier Diesel engine in the place of the gas engine.
The latest and greatest Mercuiser engines Diesel or gas use Mercury Smartcraft shift and throttle by wire so the change should be very easy.
cmmarine.com has all Cummins 4 and 6 cylinder in V drive, Direct drive, Stern drive and even Jet drives.
That's cool!
Looked like an aluminum boat too. Imagine what twin turbos would do in that thing with about 450 horses!
Thanks for the replies guys. I like that one on the gooseneck.
Cummins MerCruiser Diesel for pics and specs.
Almost all trailered boats here in the US are gas engines. They are mainly overseas in Europe and Austraulia. If you do find any here, they are VolvoPenta diesels. MUCH better on a stern drive boat than the Merc/Cummins.
I wanted to do a conversion on my SeaRay. It would be a 35K bill by the time I got done. Only paid 10 for the boat.
If you go to Sea Ray and spec out a 260 or a 280 Sundancer, you can pick the diesel option, and then be prepaired for sticker shock!!!
