2005 ram 3500 4by4,tires michlens 235 80 17.32 5thw tires ribs 235 85 16 ,11000 to 1200lbs.towing pressure for truck and 5thw,also pressure for not towing.tires max 80 lbs pressure.
I always ran my ST Goodyear Marathons at the table pressure for the weight and never had any issues. I would go 10 psi above table for interstate trips in accordance with the Goodyear TSB.
IMHO, Goodyear publishes load tables for a reason. Goodyear obviously believes they can be ran at lower pressures at lower weights.
http://www.goodyearrvtires.com/pdfs/rv_inflation.pdf
https://www.tirerack.com/images/tires/goodyear/Marathon_Special_Trailer_Applications.pdf
I was digging around looking to solid data but not many specifically state whether its good nor bad to run a trailer tire according to weight. But here's a few websites I did find that are specific about making sure to keep the air pressure in an ST tire inflated to maximum.
I'm not saying anyone is wrong but merely saying what I've been informed over the years. The accurate way to save ST tires is dont run them less than max psi, dont overload them, dont let them sit for long periods of time unmoved, keep them out of sun UV rays, make sure the axle alignment is straight, and ST tires should last a long time.
http://www.carlstargroup.com/cms_files/original/Trailer_Tires__Tips_Best_Practices.pdf
http://www.westmarine.com/WestAdvisor/Trailer-Tire-Basics
http://www.trailmastertrailers.com/pdf/proper_tire_care_safety.pdf
http://www.discounttire.com/dtcs/infoTrailerTireFacts.do
https://www.etrailer.com/faq-trailer-tire-frequently-asked-questions.aspx
