my vehicle: (2002 2500 sencond gen, nv5600, 8800gvwr) has the factory hitch under the bumber that says max trailer wt 10000 with load distributing bars...
what i need to tow once for 300 miles slowly: a 34 foot sailboat on a custom trailer with triple mobile home axles (2 have electric brakes)... the boat's displacement is 9500 lbs so i'm assuming that to be its dry weight. the trailer is surely almost 2000 lbs as the frame is made of big steel I beams. the hitch is standard with the weight distributing stuff welded on the beams...
Can i tow this much on the factory rear hitch? is it even reasonable to expect it to not break my truck? the tentative plan is to license and inspect the trailer (which has never been used on highway), rebuild all hubs and bearings and electric brakes if needed, and then tow at 40-50mph max at night on the freeway all the way from milwaukee (lake michigan) to lake superior.
I priced out hauling service and its not even close to being affordable even after all that screwing around.
people at boat yard think "its totally fine and we will just help you move the boat back a little in the cradle to get correct tongue wt" but these people also tend to hack things together so...
